02-08-2025 10:46 AM
Hello,
I have had a Pro-200 for a number of years. I simply cannot get accurate color in my prints. Ever. Now they are wildly inaccurate. I have done all of the recommended cleaning and everything appears normal in those prints, but as soon as I go to make fine art prints using Canon paper, no go.
Note, I am using Photoshop and create print images there. I have made them in RGB and CMYK. They are all terrible. I have the most recent driver and the most recent OS on my Mac Desktop. I never can find my printer listed in Photoshop. I have also used the selection of Use Photoshop to Manage Color AND Use Printer to Manage Color. No difference.
I reinstalled the printer driver today. When I pull up my printers and scanners window, it says that I have Canon PRO-200 series 2 installed, model Canon Pro 200 series AirPrint, Driver version 40.
If anyone could offer advice, I would be so thankful. This has been a very expensive printing experience with minimal success.
02-09-2025 09:47 AM
02-09-2025 09:48 AM
I just installed this software (I installed it yesterday as well). This screenshot shows the printer that appears. I believe this has the Air Print Function. Not sure if I should add it again or not.
02-09-2025 10:18 AM
It is the AirPrint version. For some reason the Canon driver isn’t showing up. Is your printer connected via USB? Did you try Stephen's site?
02-09-2025 10:49 AM
It's a wireless connection. And yes, I did try Stephen's site. I installed the software. The screenshot is what appears.
02-09-2025 11:25 AM
This is what I have. You should call Canon support at 1-800-OK-CANON. Register your product if you haven't done that already.
02-09-2025 01:51 PM
This is the driver you downloaded? And you double clicked it to install it? Then you went to add the printer?
02-09-2025 05:26 PM
I did download that, along with others ( I tried multiple drivers bc I wasn’t sure which one to use). That one did not seem to show up after installing it, but I can try again.
I have had some luck with my laptop and making a sort of okay print today, so something worked. I have no idea what. But when I print from my desktop the prints still don’t look right. But maybe I need to just keep installing, deleting, and installing.
02-09-2025 08:07 PM
Check your ICC Profiles. Chances are that is where the problem is. I have noticed that other companies have registered profiles such as Red River Papers. Such as HP Photopapers Glossy and one for Matte.
I also notice the Canon Papers do not register with ICC Profiles from other papers. There is a simple test using an old photographer's tool called the MacBeth Chart which is a number of different colors including various skin tones.
Personally I am learning to use an alternate program that fixes jpgs automatically for dpi, camera mistakes in focus and in adjusting the image for poor resolution, all of which various jpgs have a lot in common with.
I have been playing with Canon Pro-200 because they put it on sale this year in the fall. Personally I like the Hi-gloss Hi Res papers that Canon puts out. I have used various printers with the free Macbeth color chart and most of it is coming out fairly accurate. But I have used a lot of various cameras over the years. I started using a Nikon F I bought in South Korea. Then I followed up with a Polaroid 180 which had very fast black and white and 75 ASA color. That did give me an accurate idea of what I was dealing with under most lighting conditions. A parallel 64 Kodak slide film was fairly close to the 75 color polaroid.
Canon has some features on the Pro-200 with their saturation prints that no on else has.
I suggest you set it up as a wired usb printer. That might make a difference. Or not.
I also discovered my brother HL-L8360 Color Laser puts out some decent files for indexing. But basically I use the photo setting on that machine with plain ordinary hi-brightness paper. This ancient machine is not as greedy as the more modern printers as far as getting some cheap prints with good color.
02-10-2025 10:06 AM
Agree, I I have never seen Canon papers listed in Photoshop ICC Profiles. Currently it defaults to SRGB IEC61966-2.1. I don't want to go through each ICC Profile to find the one that has the right colors. When you do the macbeth chart, how does that work?
I can't wire in the printer. It has to be in another room.
I'm currently using Canon papers just to stay within brand.
02-10-2025 10:08 AM
I just reinstalled this driver this morning. Strangely it comes up as an AirPrint driver. Can't seem to get rid of it.
