Canon pro 9000 error 1200
ggusty88
How do I clear a "support code: 1200 on my pr0 9000 Mark II? Says the printer's cover is open, which it isn't. Any ideas?
Thanks.
2 REPLIES 2
Karl1
Rising Star
Hi ggusty88,
Please make sure that not only the cover is closed, but also the Inner cover.  The following picture will show you the difference between the cover and inner cover:
Inner cover open 1
Inner Cover Closed 5
If the inner cover was already closed, there is likely an issue with the inner cover sensor which would require service.  In this instance I recommend using the Contact Us link so that our support staff can recommend service options.
ebiggs1
Apparently the switch is "touchy" on my Pro 9000 II, so I need to make very sure the doors are closed. Most time I have to shut them twice in a row to get the latch to close.
EOS 1DX and many lenses.
