Canon Pro2100 won't detect clear film "paper size"
zenkengee
Hi, I have been using a roll film with white tape on the edges for several years but now when I try to print an image the printer error message is: "Cannot detect the paper size. Move the release lever and reload the paper".  I have done this 3+ times with no change.   The error does not show up with plain white paper.   I am printing the same image with the same settings from photoshop.  I have deleted and reloaded the printer from my Mac.  When I initially load the film, the printer has no problem detecting what it is, "clear film", it's only when I try to print that the error shows up.  The "how to clear" does not help.  I have also noticed that the roll loading does not align the paper with the orange line. (not sure if thats a problem or not)  See photos.  Any suggestions?  Thanks!
UPDATE:  when I load a clear sheet manually the error does not appear.
3 REPLIES 3
jrhoffman75
Does your printer driver have this setting option?
I havent seen that but I will look.  It should be 'checked' correct?  Is it in the driver?
Yes, in the driver Maintenance tab. Uncheck it if you don't want printer to check (which is what I think you want).
