10-24-2017 08:22 AM
When I upgraded to Photoshop 2018 Studio Pro disappeared. I tried to reload it and no luck. Anyone have this issue?
01-20-2018 02:57 PM
02-12-2018 06:21 PM
I had to reload Print Studio Pro and it crashes each time I open it. Mr. Hoffman, do you have any suggestions?
Thank you Randy
01-20-2018 03:02 PM
01-20-2018 03:31 PM
Following the "Next" gave me the one choice, to install for all users, without being able to direct to a speciific place.
I called Canon and, after going through several preliminary questions to route me to the right person, I got the message, "We're closed today." Worst tech support ever.
01-20-2018 04:03 PM
01-20-2018 04:05 PM
01-20-2018 10:06 PM
"Go to the Canon Utilities- Print Studio Pro folder and select Plugin Installer. "
When I do that, it gives a message: "A version of Adobe Photoshop supported by Print Studio Pro is not installed. A supported version ... is required to install the plug-in for Print Studio Pro."
I am running Photoshop CC 2018 for Mac. Print Studio Pro is supposed to be compatible with Photoshop 2018, or is that only for the PC version?
01-20-2018 10:44 PM
If you aren’t using 2.2.1 download it from Canon site
Run the plugin installer. After the LR plugin installs select Next. Select Photoshop x64 and browse to the plugin folder.
01-27-2018 03:56 PM - edited 01-27-2018 04:10 PM
Much confusion is due to poor design of the "Plug-in Installer" window. I interpreted "Folder of plug-in to be installed" to mean the source of the plug-in, given that the three adobe choices for "Compatible applications" seem to specify the destination. When I proceeded on this assumption, the installer reported success (NOT!).
Rewording the browsing instruction as "Destination folder of plug-in to be installed" would clarify. Also, renaming the window "Print Studio Plug-in Installer" would help.
01-27-2018 05:07 PM
It would alo be helpful if the installer did not say the Photoshop version was incompatible. You have to ignore that and, instead of giving up and exiting, pretend you never saw the warning and click on Next, which eventually gets you to where you can choose the plugin folder.
