Unable to find MSDS (Material Safety Data Sheet) for imageRUNNER C2236i
nuhman29
Hello there, I am looking to bring in Canon ImageRunner C3326i Copier to my country, however I was stopped because I did not have the MSDS. And I am not able to find the MSDS for this particular model. If someone knows where to get it, kindly assist me in this matter. Your reply is highly appreciated. Thanks.
3 REPLIES 3
Stephen
Moderator
Moderator
Hey there!
We're Canon USA, so we don't support this unit; however, I found it on the Canon Global site. This unit uses the NPG-83 toner. The MSDS is available HERE
Hey there,
Thanks for reaching out, I am still not able to find anything related to the printer there. When I open the links, it only show some toner models. Kindly help.
Yes, I took you straight where you need to be.
The page for the printer is HERE.
Scroll way down until you get to this section:
Then you would go to the MSDS section of the site & select imageRUNNER ADVANCE: HERE
If you need further help, you will need to contact Canon in your country or region at https://global.canon/
