SCO Unix driver for imageRUNNER ADVANCE DX 6860i
scheng
I am on a SCO Unix UnixWare 5 7.1.4 i386 x86at SCO UNIX_SVR5 OS printing to DX 6860i via raw data.
The printer prints out the first line of the entire document correctly, and then it stops.
Canon has a printer driver for this OS?
I am not an expert in SCO Unix, is there a way to view the current configuration, and change it to make the printer works?
Moderator
Moderator
Hi, scheng!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
2 REPLIES 2
Moderator
Moderator
Hi, scheng!
We hope this helps!
scheng
Thank you
