11-04-2022 10:37 AM
I had to revert to Photoshop 2022 to be able to use the iPF6400_8400_9400Series-PinPD-MacX-603 plugin for Photoshop. Could you please let me know when you will have updated the plugin for PS 2023
Cheers,
Ralf
11-05-2022 09:08 AM
Hi, Ralf! If you haven't done so already, we recommend registering your printer HERE. It lets you sign up for email updates whenever software and firmware updates are posted. Hope this helps!
02-07-2023 05:25 AM
It is now 7 February 2023 and still no sign of being able to use the PS Print Plugin on my ipf8400 with photoshop 2023 and/or Mac OS Ventura. This is pretty disgraceful. Lots of us have been using this for years and rely on it. I am having to satay with PS 2022 and Monterey in the meantime but what happens when I really need to upgrade to either or both of those? Is my hugely expensive printer just to be left obsolete?
Regards,
Philip
02-07-2023 05:54 PM
It's a disgrace.
Canon, get your act together. We're spending thousands of dollars on your ink, so please get your act together and fix this problem otherwise I have to buy an Epson next time as it only needs a driver while yours wants a plugin.
03-30-2023 08:39 AM
Hi Flup, it actually works in Ventura but not Ps 2023.
They still haven't bothered upgrading the Plugin.
Very disappointing.
05-30-2023 10:21 PM
Hi Danny,
the latest description for the ipf8400 photoshop plugin states that it is compatible with OS13 Ventura and Photoshop 2023. I have tried multiple times to install it into the plugins folder but it doesn't show up when I try to export from Photoshop. See attached screenshots. Could you please help me to resolve this problem
06-16-2023 11:59 AM
Hi Rhesse,
I had the same problem and after spending many hours trouble-shooting, finally tracked it down to not being compatible with the M1 chip. After setting Photoshop 2023 to open using Rosetta 2 (which is a workaround), the 'Export to ipf8400 Print Plug-in' option was enabled!! To enable using Rosetta, Control + Click the App name (Photoshop 2023), click Get Info, and there is a checkbox to open using Rosetta. I'll include a screenshot. Hopefully this works for you and anyone else that may be having this issue.
Glenna Bayer https://glennabayer.com/
06-16-2023 12:02 PM
Hi all,
I had this problem also. See my detailed reply to Rhesse above as to how I was able to fix it. Hopefully it may work for the rest of you.
06-19-2023 07:18 AM
That worked. Thank you so much. Finally someone with a working solution.
06-19-2023 08:54 AM
Wonderful, I’m glad that my hours of research helped someone else too!
