11-06-2024 12:14 PM
All,
In preparation for SMTP AUTH getting turned off next year, I have set up the OAuth 2.0 (Microsoft) setting in the four Canon MFP's we currently have. One machine, a Canon iR-ADV 529, will scan to email fine for about one week, then stops. Remoting in shows a "token error", so we have to disable and enable the OAuth 2.0 function again, re-authenticate using the User Code, and it works...for about a week. The other three machines do not do this and work without issue.
I know refresh tokens are valid for 90 days. Does the MFP communicate with Office 365 before the 90-day mark to get a new token automatically, or will this require us to remote in to do these every 90 days?
Reaching out to our service vendor, they state "Not much else out there other than to redo it when it happens. I'm beginning to think it isn't a reliable service, but we have no control over it. Scan to Folder is the other option you can do."...I'm working with the remote site to further troubleshoot, but outside of this one MFP, I am starting to think something on-site could be an issue.
11-06-2024 12:16 PM
Thanks for joining the conversation, rmarkwald!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
01-13-2025 01:18 PM - edited 01-13-2025 01:18 PM
Hi Mark,
I don't know if I've found the solution, but I think I know one or two things that might work.
API name | Claim value | Permission | Type | Granted through | Granted by |
Microsoft Graph | offline_access | Maintain access to data you have given it access to | Delegated | Admin consent | An administrator |
Microsoft Graph | User.Read | Sign in and read user profile | Delegated | Admin consent | An administrator |
Microsoft Graph | IMAP.AccessAsUser.All | Read and write access to mailboxes via IMAP. | Delegated | Admin consent | An administrator |
Microsoft Graph | POP.AccessAsUser.All | Read and write access to mailboxes via POP. | Delegated | Admin consent | An administrator |
Microsoft Graph | SMTP.Send | Send emails from mailboxes using SMTP AUTH. | Delegated | Admin consent | An administrator |
Microsoft Graph | Mail.ReadWrite | Read and write access to user mail | Delegated | Admin consent | An administrator |
01-13-2025 01:59 PM
Thank you for this information! I do appreciate it!
