ImagPROGraf PRO 4100S Paper Issue
wells_j
I am trying to print with sheets with the 4100S.  I am getting an error pertaining to paper mismatch that the machine is set for roll paper.  There is a roll loaded in the machine.  I can load a sheet into the paper feed but I continue to get the paper mismatch error.  I assumed when a sheet was loaded into the machine it would be detected as a sheet to be printed on but apparently not.  Does the paper roll need unloading before using sheets?  How do I set it to print on sheets?
0 REPLIES 0
