Canon iR1023 multifunsion, scanner drivers don't works to Windows 10 64bits
LeoWorld
Canon iR1023 multifunsion, scanner drivers don't works to Windows 10 64bits.
I also tried to install in Virtualbox 7.0.8, with windows 7, 32 and 64 bits adding the iR1023 multifunctional printer and if it works but not the scanner.
Please help! with any solution
2 REPLIES 2
Moderator
Moderator
Hi, LeoWorld!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
LeoWorld
ok, thanks
