Canon iR-ADV printers and UFR II Drivers
Christopheric1
I am hoping someone can help me out with printing from command line while also pushing a department ID at the same time. For instance, we have a Canon iR-ADV C5535 copier and I would like to be able to send the "lpr" command line printing to push a job, but also be able to specify the department ID as we use those here to track copier counts. We have the "allow anonymous department ID" turned off on purpose so people don't try to bypass that. I have tried using registry to push that info through the AccountMngTBL > DATA, but often come up with errors or the code doesn't get added correctly. Just wishing there was an easier way.
This was the doc I was using to see the command-line printing: https://oip.manual.canon/USRMA-0594-zz-DR-enUS/contents/dlu-cmd.html
Thanks!
James_C
Moderator
Moderator
Hi Christopheric1.
Welcome to the Canon Community Forums!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
1 REPLY 1
James_C
Moderator
Moderator
Hi Christopheric1.
We hope this helps!
