12-20-2024
04:53 PM
08:58 AM
James_C
Hello. I am trying to scan to destination folders but am not having success and I can't find the answer anywhere. I am using windows 11. I have entered the details in the send function app as:
Protocol = Cell_PC
Shared folder name = C:\Users\jg110\OneDrive\Documents\Donations
Settings on folders have been set to share to everyone
All software has been updated as well
I have tried different variations of the folder name by deleting "OneDrive" still nothing works. Any help will be immensely appreciated!
12-22-2024 09:56 PM
Thanks for the feedback, I finally got it figured out! I did put the back slashes before the hostname as you suggested. Secondly on the network path I deleted the drive the letter. Then I quit the send program, restarted the printer and voila! It works!
12-20-2024 11:15 PM
Greetings
Your path does not include a host name. I can tell you're using Windows.
Here is an example.
\\hostname\users\admin\documents
You can use your local OneDrive directory so files that are scanned to the destination will automatically upload to the cloud. You must have write permissions to the directory or scanning will fail.
12-21-2024 11:51 AM
Thanks for your response. I have tried a few different variations of your suggestion but I still get the same error message of 804.
I have tried: Cell_PC\Users\jg110\OneDrive\Documents\Donations and
Cell_PC\\C:\Users\jg110\OneDrive\Documents\Donations and neither of them work. I'm obviously doing something wrong. Can you see where I've gone astray?
12-21-2024 04:21 PM
Are you using \\ 2 backslashes before the hostname.
Also, folder permissions might need to propagate.
These are the two things I would suspect.
12-22-2024 05:00 PM
Here's how I have it configured:
\\http:Cell_PC\C:\users\jg110\One Drive\Documents\Donations
I have all shared permissions checked
Starting to litter my floor with all the gray hair I'm pulling out!
Thanks!
12-22-2024 09:56 PM
02-24-2025 09:25 AM
So what was the final path name? I'm having the same problem.
03-03-2025 10:59 PM
This is the final path for my set up.
Host name: //Cell-PC
Path: Users\jg110\OneDrive\Documents\Household Receipts
Change things to match names that you used. Hope it works for you
03-03-2025 11:27 PM - edited 03-03-2025 11:27 PM
Note you have to use backslashes on the host name 😉 \\hostname
You can use forward slashes in the path / 🙂
