04-21-2025
05:02 PM
06:09 PM
Tiffany
I have an MF733Cdw running on house WiFI. All equipment is Apple (Macs, iPhones, iPad). My mac is a mini 2023 (M2) running Sequoia 15.4.1. Everything was working just fine. I can print with no problem. However when I push Open Scanner button the Image Capture window has everything grayed out, even the three colored dots in the upper left corner. In the window it says No camera or scanner selected. Rebooting doesn't seem to work. This is a new problem. Suggestions?
04-22-2025 06:38 PM
04-22-2025 07:07 PM
OK, finally got the drivers released 4/22/2025. Installed printer and then scanner driver. Added back the printer. That works fine. The scanner does not appear, which was the original problem. How do I get the scanner added back?
04-22-2025 07:52 PM
Mysteriously the scanner is back! Let's hope it stays. Thanks to all for the suggestions.
