imageCLASS MF244dw Print Driver not working on Mac OS Ventura 13.0.1
rajhair0ra
I'm having a similar problem with Ventura, using MF244 printer. Downloaded the latest software and lost printer connection. During setup, error: "Unable to communicate with the printer at this time". It worked for printing and scanning prior to Ventura upgrade, and only stopped printing when I downloaded the new software. Thank you!
3 REPLIES 3
I would suggest, removing the printer instance, and uninstalling the "old" driver used with the previous OS version. Restart, then run the new installer following the prompts for configuration and detection.
Thanks for your suggestion - i tried that and still get an error during setup
fastorga69
Same here with MF620C
