10-09-2024
04:47 PM
04:52 PM
Tiffany
My Imageclass 227dw laser printer worked great with iPhone and iPad until iOS 18 update. My devices show my printer in the print window, but when I click “print”, the window goes away and nothing prints. Apple tech tells me they’ve recorded numerous complaints about this problem with Canon printers. Any known fixes out there?
12-14-2024 10:02 AM
My problem seems to have been resolved by a simple work-around. When I’m in a website or document and I select AirPrint I then click on the square with the up-arrow (in the Air Print window) and am presented with a number of choices that include the Canon Print app. When I select Canon Print, I’m able to make my print-setting choices and print.
12-14-2024 08:59 AM
Same problem here. I haven’t been able to scan for years either. I’m thinking after a decade it might be time to look for something new and supported. It was a good run and it’ll be a great pickup for someone at the thrift store!
12-14-2024 10:02 AM
12-29-2024 11:18 AM
Having the same problem with IOS 18.02 and my Imageclass printer. But I’m not following your workaround. Screenshots, please?
12-29-2024 03:16 PM
(To print from an iPhone or iPad)
You need the Canon Print app installed from the App Store and set up for your printer:
If using Canon Print (instead of AirPrint) to print your desired document/image isn’t possible, click on the box with the up-arrow to access AirPrint. From the AirPrint box, click on the box with the up-arrow:
That should bring you to a dialogue box that looks similar to this below, where you can select Canon Print.
Once in Canon Print, you should be able to output to your printer.
12-30-2024 07:51 AM
Prescott….Thank you so much. I have an Imageclass printer and am struggling to set it up on the app, which does not recognize it. Guess I will have to pray to the Apple gods to fix this glitch in the new IOS.
12-30-2024 08:02 AM
My printer couldn’t be found automatically. I had to determine the network address (IP address can be found through the printer display’s settings). Once I entered the IP address into the app, it all worked fine.
12-30-2024 08:13 AM - edited 12-30-2024 09:03 AM
I too had to add mine by IP. Likely very important to have a fixed IP on your printer. It’s possible it may discover a new one after making the initial connection and it changes, but unlikely.
12-30-2024 08:44 AM
We’ve spent the last half hour trying to find the IP address without success.
12-30-2024 08:56 AM
Ok, found IP address. Where to enter it on the Canon Print app? (Thanks for your patience!)
