07-18-2024
10:14 PM
11:51 AM
I Bought a Pixma G3200 printer/scanner in 2022, I recently purchased a new desktop with Windows 11.
How do I download the print Drivers? Specifically, the IJ Sanner driver?
When I go into Support and Drivers download, It detects my Windows OS. But it does NOT list any drivers for me to Download.
It only says ' There is no versions for the OS selected'.
I am assuming this is because the drivers have not been developed yet for this printer and Windows 11??
When will those be available? or is there another way to download the drivers? Maybe for Windows 10?
07-21-2024 08:32 PM
However, you did show me the error in my ways:
After seeing the Windows detected, I failed to see that I had to ALSO select what VERSION.
After selecting the Windows 11 Version (as you suggested). I Now have download options.
And thanks for your explanation of the different options available.
07-19-2024 07:06 AM - edited 07-19-2024 07:10 AM
The G3200 is a series, not a model. I'd like to confirm your printer is a G3270? If this is your model, please visit the following page.
https://www.usa.canon.com/support/p/pixma-g3270#idReference%3Dsoftware-drivers
Click software and drivers. Select Windows / Windows 11.
There are about 8 options. Look for Master Setup, and / or the other is called Print Driver and IJ scan Utility. Here's the difference. The Master Setup will install the printer and scanner driver, it also gives you the ability to install optional software, like Easy Photo Editor and Poster Layout Lite.
The printer driver and IJ scan utility package will only install what you need to use the product for printing and scanning.
The optional software can be downloaded and installed at any time, so you're not missing anything by using one or the other.
07-21-2024 08:23 PM
Sorry I have it registered as a
MegaTank PIXMA G3200 Wireless All-in-One Printer
SN KKSB27948
07-21-2024 08:32 PM
