02-08-2015 12:47 PM
Just bought the Canon MG6620 and I have connected it to my Home Network with out a problem and she is working great! But it connected to the 2.4Ghz Band of my router. But I was just wondering does this printer support the 5Ghz Band which I would much rather connect to?
02-12-2015 02:04 AM
Hi tjisret,
The PIXMA MG6620 is not compatible with the 5Ghz band of routers.
02-12-2015 02:04 AM
Hi tjisret,
11-03-2015 04:26 AM
What Canon printer does support 5 GHz? In my environment 2.4 GHz is too crowded and I moved my whole WLAN to 5GHz.
11-05-2015 11:11 AM
Hello.
Our printers are not able to connect to 5.0GHz networks. If you have a printer that has an Ethernet connection, consider using this connection instead. Devices that connect to the same router should be able to access the printer this way.
If additional assistance is needed with this matter, find more help at Contact Us.
08-04-2016 03:08 PM
08-04-2016 03:09 PM
08-06-2016 11:19 AM
tinyteri,
A standard Wi-Fi router will be needed in order to access the printer wirelessly over a network. If one is not available, the printer will have to be connected to your computer via USB cable.
08-12-2016 07:54 PM
08-12-2016 11:41 PM
08-12-2016 11:41 PM
