Ts3522 Can't Get It to Connect
Young21967
Just bought this and can't get it to connect.  I have a Arris Surfboard, 2.4/5G, and have s[ent the last 4 hours trying to get it (the printer) to connect to either of my laptops.  I just found out that it will now work with 5G, but can't find any info on how to link in wireless to the 2.4G of my router.  Any help would be appreciated by me, my wife, and the printer that's very close to getting a sledge hammer being used to strike any key.
1 REPLY 1
The printer only has a 2.4Ghz radio, it cannot connect to a 5G broadcast.
Hi-Speed USB
Wireless PictBridge
Wi-Fi® (802.11b/g/n wireless networking, 2.4 GHz)
Wireless Direct Connection (Access Point Mode Only)
I suspect you might be using the same SSID name for both of your wireless networks?  This can confuse devices that only support a single band (2.4Ghz) in this case.
Log into the Arris (it should use) 192.168.100.1 and temporarily disable the 5G broadcast.  Now verify that the printer is connected to the 2.4Ghz wireless broadcast.  Test printing.  Once complete, you can re-enable the 5G broadcast.
Note, if you have other network devices present, mesh system, extenders, etc, the IP of your gateway (arris) (192.168.100.1) might be different.
