08-02-2014 02:36 PM - edited 06-05-2016 01:37 PM
Could not complete driver installation during brand new set-up because of this message. Went through wirless connection set-up several times and connectivity was always present. Logged into my D-Link 626L router and could see the printer connected but the ip address referenced was 0.0.0.0. Tried to assign a static ip address through set-up on the printer and also use the cmd prompt in windows, all to no avail.
Called Canon Support and these 2 setting changes solved the problem:
1) Disable the Wirelss LAN DRX setting
2) Disable the IPv6 Setting
This article explains how to adjust the settings on the printer.
06-05-2016 01:33 PM
Don't believe it is a "windows" issue, just bad driver installation that has yet to be corrected.
06-06-2016 12:24 AM
Well, for me, I had the drivers already installed when I "upgraded" to Win 10 and they worked fine. Until the first time I had to reset Win 10. Then I reinstalled, worked fine, had to reset. Then I reinstalled and, again, my printer was working fine for quite some time. The drivers were installed, they were working fine, then several Win 10 updates later they stopped working. The installation was not the problem.
Not saying that installation might not be a problem for others but for me? It makes no causal sense whatsoever.
09-23-2016 06:46 AM
You found the solution but You don't tell how to disable ipv6 or lan drx settings. I have windows 10.
09-23-2016 03:03 PM
I guess you didn't see the posted link in the solution that takes you through making the changes on the printer.
https://support.usa.canon.com/kb/index?page=content&id=ART116513
thanks
11-25-2016 02:27 PM
Trying to set up wireless connection on laptop. My Prima MG7750 printer does not recognise on my Windows 10, 64.
I followed instructions and disables IPv6 but still no joy.....4 hours in, any suggestions?
12-12-2016 03:00 PM
I have a canon mg3520 I have been trying to get it to connect to wireless for over a week it just will not work no matter what I do PLEASE HELP
12-15-2016 05:57 PM - edited 12-15-2016 06:02 PM
No idea why this is marked as solved becuase it certainly is not solved. Have been meaning to post the solution for awhile but hate signing up for even more accounts to do so.
With a Canon MG6620 the printer can never be detected when using "mp68-win-mg6200-1_02-ejs.exe" version driver. This used to be the driver listed here:
but it has since been replaced with the driver that always worked which is version "mp68-win-mg6600-1_01-ejs.exe"
Bottom line use an old version of the driver or look here: https://www.usa.canon.com/internet/portal/us/home/support and find the driver for your model and try again. Since Canon removed the not working 1.02 driver version for the MG6620 it is likely they also removed the driver that was causing problems for other models.
Now the issue is solved. It's so dumb how issues on forums like this get marked as solved when they are so far from solved.
01-05-2017 04:31 PM
I have mg3660 that isn't connecting wirelessly either. I wish I had bought a LCD screen one as it's so much easier!!! I will try and add the Mac address of the printer to my security setting in my router (netgear) and see how that goes. Why do they make it so difficult?? I tried the ubiquitous connection but it said it could not find the port and I could not create a port for it when I searched for the solution. In very disappointed in Canon. Let you know how I go.
01-05-2017 07:22 PM
After 40mins of Canon phone support I got an ip address! Had to press the dps button on my router and also extend my ip address range on my router. Used the main setup software and it took a while and even if it failed to detect printer at first just keep going until I connected using the usb method. Disconnected when it told me to and it then set up the connection to my router. Successfully printed from ipad, laptop after it got an ip address. In short, just call their support line and hope you get someone good.
01-06-2017 06:11 AM
Sorry for the spelling mistakes. Meant to say I pressed the wps button for five seconds on my router after I pressed the Wi-Fi button on my printer until the power light and Wi-Fi were flashing. I had to restart my router after the Wi-Fi blue light kept flashing. After that I did get an ip address. I had to restart my laptop after tried the set up as it failed to detect the printer. It does take a while but eventually my laptop picked up the Wi-Fi when I ran the master setup and chose the Wi-Fi using usb method. Hope this helps a little.
