06-19-2022 11:20 PM
I play with the levels in photoshop and set it a tad too bright. So the printed result tooks more like what I see in on screen before I set the levels a bit too bright. Many suggest this is because monitors are set too bright. But this confuses me. Does this mean all professional stockphotos that look good in brightness on my monitor. Are in reality too dark?
06-20-2022 02:25 AM - edited 06-20-2022 02:26 AM
Your results will largely depend on multiple components in your workflow. This starts with your camera and the images you are capturing. Then the following: correct monitor calibration, color profiles and using correct printer settings for thr type of paper you have selected.
What is a "stockphoto"? Is this a unprocessed RAW or jpeg file? Are your displays using the same color profile as your camera?
If your monitors aren't calibrated, it wil be nearly impossible for you to achieve consistent results when printing.
If you want to provide more information about your hardware, camera, monitor(s), printer, etc. we can offer a little more info. Again however, all aspects of your workflow need to be evaluated and considered.
