10-04-2023 03:14 PM
Installed Sonoma OS on Mac last night
Today my Canon MF743 works intermittently
Seems to be able to handle single page docs... but when I try to print multiple pages the Print Center shows that the printer is "waiting"
Called Canon and Apple twice today - no one seems able to figure it out
And yes... we've removed and re-installed the driver multiple times
Any clues???
10-17-2023 07:13 AM
resetting the IP address and reinstalling the expanded print drivers - am guessing everyone's situation is different and wouldn't suggest this as a blanket fix
10-13-2023 01:26 PM
I'm having the same issue. I have a MF733Cdw, with the same symptoms. Tried it with 2 different Macs with Sonoma, same issue, I send a print job, and it looks like it's printing but then the job gets stuck in the print queue. The printer queue itself doesn't see it, so the issue seems to be between the driver and the print queue.
I have tried removing the drivers and installing the latest ones, which state on the site that they support Sonoma, but I think there is an issue with them.
I have even tried to change the print drivers from CUPS, with the same results.
Every so often, restarting the machine would release a pending job and sends it to the printer, but more often it just doesn't print. It's very frustrating. Any way we can get a solution? the printer is an older model, not sure what's the best way to contact Canon support? is the phone number the best way? or do we need a Carepak to ask the question?
10-16-2023 07:27 AM
I called Canon at (800) 652-2666 and they did a great job helping me troubleshoot and get things working again.
10-16-2023 10:04 AM
great! Thanks! I will give them a call! glad things are up and running for you!
10-17-2023 05:50 AM
And that solution is.... ?
10-17-2023 07:13 AM
12-07-2023 02:15 AM
What does re-installing the expanded print drivers? I can't find any updated drivers for Sonoma
