11-11-2024
11:45 PM
10:32 AM
Hello!
I have been using my Canon Pixma MG3620 to print shipping labels from my phone for over a year now. Recently, I switched wifi carriers from Cox to Verizon and ever since then I have not been able to setup the wifi connection to the printer from my phone or computer (I understand a solution would be to switch back, however, everything other device has had no issues and the monthly rate is cheaper😅). I have found prior discussion posts and have almost gotten it connected, but usually before the last step, the little yellow light next to the lightning bolt in a triangle starts flashing, and it never works. I searched for anything about the yellow light but found nothing.
I had finally given up on that and bought a printer to USB-A cord (I don't know if it came with one and I misplaced it? I'm desperate at this point😭), and found a discussion post about setting up a USB connection, in which I always get to the last portion where it has me test run the printer. The printer does nothing, and in the printer's queue it just says, "Offline." I am not as worried about the wifi connection as I am about using the cord because I feel like it shouldn't be this difficult to print something with a physical USB cord? Please, help me!😩
I have attached the links for the discussions I have followed that have not worked & would greatly appreciate any and all advice! Thank you in advance!🕺
Setting up Wifi Connection (I used the Caemene's accepted solution)
11-13-2024 04:00 PM - edited 11-13-2024 04:05 PM
Hi phillbow1,
Please try setting up your PIXMA MG3620 for use with Wi-Fi by using the WPS Pin Code method.
You will have to log into your router to perform this.
To connect your printer using this method, please view the steps here:
Wireless LAN Connection With the WPS PIN Code Method - PIXMA MG3620
