08-31-2021 09:59 AM
TS9100 printer/canner
Printing and scanning fine until today.
No changes to home network. I run wired network through several switches. All other devices fine on network/switches.
Run Norton 360 also (if that matters).
Printed a document today via home network. But IJ Scan Utility cannot find printer/scanner.
I restart everything and print a test paper.... it prints fine but Printer stays in Print more even after single page printed.
I then have to STOP printer.......
Scanner still not found before or after restart.... ugh!
Any thoughts on what is going on?
09-02-2021 10:10 AM - edited 09-08-2021 07:38 AM
Well it seems fixed Moved the printer to another network switch and it worked. Then put it back to the original network switch and its working fine... gremlins!
