‎06-15-2021
05:07 PM
‎09-24-2024
12:07 PM
Hello everyone!
I've been struggling with this all day. I just bought the Pixma 8720, I don't have a disk Drive on my mac to download the software so I went online to get the Driver and Software.
Followed the instructions and I'm stuck. I went and bought a USB cable so it's now officially hardwired and works fine, But I can't get it to connect wirelessly. Everytime I go to setup I'll run through the installation no issue. I get the "setup disk" on my desktop I'll get the prompts then when it goes to look for the printer on wifi it glitches out and nothing else will pop up on my screen
I'm currently running Big Sur 11.4 on my Mac is this the issue? Is there a way to connect it wirelessly through a wired connection. I've tried to find youtube videos or anything to help me. Any information would be so helpful. Thank you so much in advance.
‎10-08-2021 07:58 PM
‎08-13-2021 01:32 PM
Hi ubebae,
Please use the Canon PRINT app to connect your PIXMA iP8720 to your wireless network.
You can install this app on a cell phone or tablet/iPad. Once this app is installed, please close the app and follow these steps:
1. Turn your iP8720 on. Hold down the Wi-Fi button and then let it go when the power light blinks 2 times. The Wi-Fi light will start to blink on your printer.
2. On your mobile device that you installed the app on, please return to the main screen.
3. At the main screen, if you are using iOS, tap Settings and then tap Wi-Fi.
If you are using an Android device, open Settings, tap Networks or Connections and then Wi-Fi.
4. In the list of Wi-Fi networks that appears, select the canon network.
5. Once your mobile device is connected to the canon network, open the Canon PRINT app that you just installed.
6. "Do you want to search" will appear, tap Yes.
7. Select your home wireless network name and enter your Wi-Fi password.
Your PIXMA iP8720 will connect your Wi-Fi network.
‎09-19-2021 11:10 PM
‎10-08-2021 03:53 PM
I'm having the same issue with my Pixma ip8720 printer. I recently got a new modem/router and have reset the network settings on the printer. I've connected the printer via USB, but have tried everything suggested anywhere that I've found info without success. This is the first thread I found using the iphone App and was very hopeful, but same result. Please provide some additional troubleshooting suggestions.
Thx, Ed
‎09-21-2024 01:16 PM
I am having the same issues, about to throw printer I am extremely frustrated. My phone is now saying Canon_ij_Setup no internet connection HELP PLEASE!
‎09-24-2025 01:57 PM
Thank you Patrick. After trying every conventional method of connecting this unit to my wifi, using the Canon Print app worked perfectly. You should really repost this procedure on Reddit!!
‎12-21-2025 03:30 PM
in case someone is still having trouble. I had the exact same problem. App was no help. Here is what did it.
Reset printer to factory default (hold middle button until on/off light blinks 15 times)
go through USB setup on computer and when it says it cannot find the printer, you'll have a checkbox on the lower left that says use USB cable, check that and click next. It should be fairly straightforward to go through setup then, except (don't worry that you may not be able to type in the password for your network when wifi networks are shown in the list), but eventually, it will ask you for printer password (just when you thought you were done 🙂
put a sheet of paper in the printer feeder. Hold middle button again until on/off light flashes 6 times. Page will print and at the bottom of it will be printer admin password. That should be it. If you still have trouble, let me know. I'll post more detailed instructions.
