06-11-2024
04:56 PM
12:00 PM
James_C
I have a new TS3522. I followed the setup but I am unable to establish wireless. I bought a USB cord so I can use the printer, but would prefer wireless.
I printed (no choice but to print) the Network Configuration Page but the IP address of the printer (reference section 3-2-12) is not listed.
Where can I go for help?
06-11-2024 07:08 PM
Welcome to the forum!
So that the Community can help you better, we will need to know the which version of Windows or macOS are you using? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you.
06-11-2024 08:40 PM - edited 06-11-2024 08:44 PM
In order for us to provide specific information for set up and wireless connection, please answer Tiffany's questions for us.
Wireless Set Up: Windows / MAC
Canon Knowledge Base - Easy Wireless Setup With Windows - PIXMA TS3500 Series
The most common step which is often missed during wireless set up is pressing the wireless connect button before running the Software Set up application. This has to be done for the printer to detect your wireless network and associate.
The printer supports a 2.4Ghz wireless broadcast which supports WPA2 / AES encryption. It will not connect to a 5Ghz broadcast. Please ensure your network meets these standards.
Once you have installed the device as a USB printer, its often best to uninstall and remove the printer, then disconnect it from USB before running the wireless connection set up. Otherwise, you might get two installed devices, with only one that works.
09-03-2024 11:56 AM
i don't know why this worked for me, but it did. i downloaded the canon print app on my phone, did the setup, chose my (new) internet connection... and now I can also print wireless from my pc. it took a couple of hours to get to this point; i wish you well on getting your issue resolved also.
09-03-2024 11:57 AM
by the way - my new internet is t-mobile 5g gateway. my previous internet did not give me the difficulty....
