05-12-2023
08:54 AM
09:02 AM
Good morning, how do I check whether I am printing using Canon's drivers instead of my iMac M1 drivers?
Thank you
05-12-2023 09:23 AM
Easiest way is to look at the printer's properties. There is a field called "Use". This usually states the name of the printer. If it states something like Generic PCL or Postscript, you might not be using the "Canon Driver".
If you are in doubt or unclear what you installed, visit the support portal for the pro-100. Remove the printer and re-install using the Canon driver.
Canon Support for PIXMA PRO-100 | Canon U.S.A., Inc.
05-12-2023 09:28 AM
Along with Rick’s response, if you see 3.0 as the driver it’s Apple AirPrint. You want something like 16.70.00; (I’m away from my MacBook).
05-12-2023 09:43 PM
Hi, I do see 3.0. I had removed the printer and reinstalled it though. If I remove the printer again, how do I get "see 16...."? Thank you in advance.
05-12-2023 09:45 PM
When you remove the 3.0 version select the “+” button to add a printer and wait possibly a few minutes for the IJ Series version to appear.
05-12-2023 09:53 PM
Sorry, just did it. Thank you.
05-12-2023 09:56 PM
So you have the Canon driver now?
