02-24-2020 04:17 PM
I am new to forum so bear with me. All of a sudden my printer quit connecting with my Netgear modem router. All other devices through the router are connected so I know it is not a router problem. It is usually easy to connect through WPS button on router but I have tried all the options andd nothing works. I have unplugged, reset both printer and modem. Any other suggestions? Hate to buy another printer if this is a small fix.
02-26-2020 03:24 PM
Hi angelgirl,
Please follow these steps to connect your PIXMA MX922 to your wireless network:
1. Press the MENU button on your PIXMA MX922
2. Repeatedly press the down arrow to select the wrench and screwdriver icon and press OK
3. Use the left arrow to select Device settings and press OK
4. Use the arrows to select LAN settings and press OK
5. Use the arrows to select Wireless LAN setup and press OK
6. Does a WPS message appear? If so, please press the STOP button 1 time (to select Other setup options)
7. Select Standard setup and press OK
8. Select your wireless network name from the list that appears and press OK
9. Press OK to access the on screen keyboard and enter in your wireless network password. Please note that this password is case sensitive and if it is entered incorrectly, your PIXMA MX922 will not connect to your network. To switch between upper case letters, lower case letters and special characters, please use the middle function button below the LCD of your PIXMA MX922.
10. Press the left function button under the word "Done" once the password is entered
11. Press the left function button under the word "End Setup"
