05-16-2024
05:38 PM
12:07 PM
Stephen
Hello,
I recently got a computer, and I need to get the drivers for my PIXMA MX922 in order to use it- However, it appears that the page has been removed from the canon website.
https://www.usa.canon.com/support/p/pixma-mx922#idReference=software-drivers This page 404s [Mod note: corrected link]
https://support.usa.canon.com/kb/index?page=content&id=ART170972 This is also unhelpful
Is there any place where I can get the drivers?
Thanks!
12-01-2024 12:30 PM
I tried that link too and got the same result. It took me to the same location with older driver files. Do you have a driver that works with a windows 11 laptop that has an ARM-based processor?
12-01-2024 12:44 PM
I apologize. The OP was because the link was broken and needed to be fixed.
The issue you're facing is that there is no driver for your printer using Windows 11 on ARM. Please see THIS page for info on that.
12-01-2024 01:06 PM
The page you linked to says that my MX922 is compatible with the ARM based processor. The only thing I haven't tried that it mentions I do is connect the printer to my laptop via USB. Is that correct?
12-01-2024 01:29 PM
From the Knowledgebase:
If you want to use your product via USB with a Windows 10 or 11 device running on an ARM-based processor, simply plug your device into an available USB port. A driver will be installed automatically.
[OR]
If you want to use a printer across a network:
