10-27-2024
03:13 PM
11:24 AM
Just obtained a MacOS Sonoma 14.5 (23F79), and can no longer connect to my Canon MG3520. Help! I've tried to add printer and received a reply that the developer needs to update.
10-27-2024 03:53 PM
Looks live Big Sur was the last supported OS.
09-13-2025 09:03 AM
Although this might be a bit late, I just installed Sonoma and my MG3520 just quit. After a lot of messing around try this link and download the ICA Driver. Before installing the driver, you may want to go into Finder and follow the path: Macintosh HD/Library/Image Capture/Devices and delete all of the Canon drivers if you have only one Canon scanner/printer. That way the scanner drivers for Canon will be clean and fresh. Now install the driver.
https://www.usa.canon.com/support/p/pixma-mg3520
Good luck.
