PIXMA MG2929 How to connect to iPad via cable
Jeffinerd
Good day! Please tell me what cables I need to connect my PIXMA MG2929 to my iPad Air 11”(M2) OS 18.6.2. I do not have Internet available to do it wirelessly. Thank you!
modike8171
Hello,
Since the Canon PIXMA MG2929 printer and the iPad Air 11” (M2) do not have a direct wired connection port that they share, you cannot connect them with a cable. The PIXMA MG2929 relies on a wireless connection for printing, and there is no direct cable option available to connect it to an iPad.
Best regards,
aessuccess login
Rachel
4 REPLIES 4
modike8171
Hello,
Best regards,
aessuccess login
Rachel
Jeffinerd
I’m flat out of luck then
can I use the hot spot on my phone or tablet to connect with the printer wirelessly?
Greetings ,
No, this is not possible because devices connecting to your mobile device's hotspot are isolated from one another.
The MG2929 supports wireless direct.
Canon : PIXMA Manuals : MG2900 series : Setup Guide https://share.google/jX3rUP4g6L83flERO
This means you can connect your mobile device directly to the printer and print using the Canon print app.  Follow the instructions above to put the printer into access point mode. Open the Wi-Fi settings on your mobile device and look for the printer's broadcast.  Once the mobile device is connected to the printer, you will be able to use the Canon print app.
