PIXMA G7020 says offline
cernicalo
Hello everyone. I need help badly. This problem is really frustrating. I have a Canon Pixma G7020 printer. It was working fine until a couple of days ago. When I try to print something, I get a message that says the printer is offline. I have tried downloading the driver several times to try to correct the problem. When I get to print a test page, the printer will print the test page, but when I try to print a document, then I get the printer is offline message. I have tried with the ethernet (wired) set up, and also the wifi set up and get the same results. I really like this printer except for this. I have seen that others have had this problem as well. What did you do to correct this? Please help!!!
Thanks.
2 REPLIES 2
Patrick
Hi cernicalo,
There are many reasons why this may occur and unfortunately would take a very long time to resolve via forum posts.  Because of this, it is recommended that you contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your product and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support.  A Technical Support Representative will be able to resolve this issue quickly for you via phone or chat.
cernicalo
thank you for replying. I did find a solution after scrolling through others that had the same issue. I deleted the printer from my computer and reinstalled it. It works so far.
