PIXMA G7020 - Will not connect via Wi-Fi - Connection failed
BJM2025
It did work initially but would always go to sleep and then say offline. After reinstall is says connection failed. I  have downloaded and installed all the latest software dated 2/7/2025. ex.Wi-Fi Connection Assistant Ver.1.9.1 (Mac). It works fine and I can print using the Canon Print app on my iPhone. I even tried a physical LAN cable directly from the router to the printer but that didn't work either. It finds the printer, IPv6 as it's a 5G network, but when I get to the end when it says Add Printer, it never appears. For firewall settings I allowed Canon Wi-Fi connection Assitant.app. Should I allow others? WiFi agent? My Mac is a 2023 with the M1 chip and the software is Sequoia 15.3.1. Thanks.
5 REPLIES 5
Patrick
Hi BJM2025,
Please contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your Canon printer and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support. A Technical Support Representative can determine the cause of the issue and resolve it for you quickly via phone or chat.
This sounds like an issue with your network configuration. I would suggest assigning the printer or static IP on the network. Now remove the printer from your MAC and restart.
Now install the printer as an IP printer on your system.  Assigning the static IP ensures persistency.  It ensures your printer always gets the same IP from the router, regardless of how often it's used..  turned on turned off, goes to sleep, etc.  when you use DHCP,  the leased IP can expire but your computer will try to use the last connection method anyway.  If the IP has changed the printer will show as offline and will not receive print jobs.  Address reservation or assigning a static IP only has to be done once.
Thanks Rick but dont know how to add a static IP address? Pretty good with windows but not so much with Mac.
Thanks Patrick I will have to do that.
A static or reserved IP is made on your router.
Once done, Open the printers and scanners dialog in Mac OS.  The icon one over from the left in the Add printer applet allows you to add a printer using its IP address.
Friends and Family
