12-15-2023
09:22 PM
10:02 AM
Hi
My printer keeps going offline. I have uninstalled and reinstalled the printer, turned on/off modem and printer. Sometimes it prints and sometimes it says offline and won't print. Why does it keep doing this? It is very unreliable when I need to print things. Any suggestions are greatly appreciated. Thanks! Sandra
12-16-2023 08:16 AM - edited 12-16-2023 08:16 AM
Thanks for joining the conversation, Sandra!
So that the Community can help you better, we need to know exactly which Canon printer model you have, which operating system is running on your computer (i.e. Windows or macOS, and which version thereof), and whether your computer and your printer talk to each other via Wi-Fi or via a USB cable. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
12-16-2023 05:32 PM
I’m also having this problem with my G6020. It started after I noticed and complied with the request to do a firmware update about two to three weeks ago. I’ve had nothing but trouble since then. I’ve rebooted everything—printer, devices, router—multiple times. I’ve reloaded drivers on all devices. I’ve attempted set up multiple times. It’s like the printer is invisible to WiFi. I’m running all Apple devices, and most are new—a MacBook Air, two iPhones —a 15 and a 13, and multiple iPads. None will connect and I’m beyond frustrated. I use this for a small business and I have to take the files elsewhere to print things I need for Monday. Prior to this, the printer was wonderful. Then it kept shutting off, which made Airprinting a pain. Then I had to restart the router every time I wanted to print and now it won’t connect via WiFi at all. It really appears as if your update broke something and I really hope you fix it. Otherwise, all I have is a large Canon paperweight.
03-30-2024 06:23 PM
Hi, I have a canon G6050 that has the same issue, continual disconnection, prints 1 job if I~ get it back the looses all connection.
It is a terrible printer to use! Really bad..
Is there an update on this, I have had advice from canon blaming my wifi having both 2.4ghz and 5ghz. Just about every wifi splits this way, canon connect on 2.4 and say that this is not their problem! Really!
03-30-2024 07:11 PM
Welcome to the community Zoomy.
Since this is a thread started by someone else who has a different model device, could you please start your own topic. This ensures your issue receives the visibility it deserves.
Your post should include a statement about your problem or issue
The model of you Canon device: G6050
The operating system (version and build) you are using it with
How it is connected and to what. (wireless)?
Information about your wireless network. Router brand / model. How is it configured, etc?
Any troubleshooting steps you've performed, error messages you've received.
We're happy to try and help. Thanks in advance.
02-21-2025 05:01 PM
I have the same issue. I use my laptop running Windows 11and connect wirelessly within a few feet of my router. I use my computer every day, sometimes it is powered off overnight and sometime not. Regardless, when I try to print I get an error message that the printer is offline. I have also uninstalled and reinstalled the printer, downloaded the current firmware and tried to use the Canon Print app to troubleshoot. This week the Canon Print app - reinstalled 2 days ago - won't even load. This issue is frustrating and unacceptable
06-30-2025 06:04 PM
I've been dealing with this issue for years on my PIXMA G6020! I've updated my bios, LAN/wifi chipset drivers, printer firmware, disabled sleep mode on the printer, uninstalled/reinstalled the drivers, re-setup the printer through the installer, setup a static IP address, etc. It keeps happening!
At this point, it has to be a faulty wifi controller that you're installing on your printers. What are you going to do to actually address the issue?
06-30-2025 06:28 PM - edited 06-30-2025 06:49 PM
I understand you're frustrated, but this topic is now splintered with four or five people replying with different device models and different operating systems. This makes it very difficult to offer solutions. It's also not possible to mark a topic as solved unless it's your own. Your issue deserves its own thread and visibility. This allows community members and Canon Experts to provide relevant solutions specific to your device, problem or issue.
In many cases, network configuration can contribute to intermittent connectivity of devices on your wireless network.
Persistent devices (like printers), that do not "come and go" should be assigned a static or reserved IP on your router. This way the printer (persistent device) always gets the same "destination" IP. This in turn ensures reliable and consistent connectivity. People can visit, devices can connect and leave, but the printer's IP remains constant. This is a common network practice that only needs to be done once. If you need help with this, please start your own thread provide the information I mentioned above and someone here will be happy to assist you. 🙂
07-01-2025 07:30 AM
I shouldn't need to start a new thread for an issue that pertains to the title of the thread. I have a PIXMA G6020 that goes offline as stated in the title of the thread. Creating multiple threads for the same topic makes finding a solution more complicated for someone looking for an answer.
I understand others are posting for other models. That's not a problem that I need to address rather the poster or Canon community moderators. My question, according to the title, pertains and contributes to trying to find a solution.
04-11-2026 08:58 PM
Does anyone ever get a satisfactory answer to this problem? How can a printer disconnect in a middle of a print job, on a wireless router and operating system it has been using for many months? And I have done all of the above too.It accepts the wireless password, acts like all is fine, and then it won't connect. how could it work with 5G for months, and then suddenly decide it doesn't want to do that any more? I shouldn't have to be an IT specialist to try to make an expensive printer work (G6020). It told me "your computer is currently connected to a network with a frequency not supported by your printer". well, it has been for months up until now. so it's not an IP address issue, obviously. something changed - mid print job?!?!
