No Canon lbp6030w printer driver and wireless setup software found for MacOS Sequoia version 15.5
yawatcanon
Hi, I can't find any Wireless setup software and/or driver software to set up Canon ImageClass lbp6030w printer access from my new Sequoia, MacOS version 15.5. Please let me know if there is anyway to set up the Canon lbp6030w printer access on my Sequoia MacOS (new mac mini).
Stephen
Moderator
Moderator
It’s understandable that not finding a dedicated wireless utility would be a roadblock in your setup. For the imageCLASS LBP6030w, that tool is actually tucked inside the main driver folder rather than being a separate download.
Here is the best-effort path to get that wireless connection established on your Mac:
  1. The Download: Head to the Canon Support page and grab the [Mac] UFRII LT Printer Driver Ver.1.5.15 (macOS 10.15.7 - macOS 26.2) for your specific version of macOS.
  2. Mounting the Disk Image: Once the download finishes, double-click the .dmg file to mount it, then run the installer package inside.
  3. Locating the Tool: After the installation is complete, the software isn't "hidden" anymore. Open your Applications folder, look for the Canon folder (or Canon MF Utilities), and you will find the Canon MF/LBP Network Setup Tool.
  4. Execution: Run that utility and follow the "Wireless LAN Connection" prompts to connect the printer to your network.
If the printer still isn't showing up on your network after these steps, it might be a communication issue between the unit and your specific router settings (like a 5GHz vs 2.4GHz band conflict). In that case, the best next step is a quick call to 1-800-OK-CANON. Our technical team can verify the connection status and help bridge that gap for you.
Official Canon Sources
Verification Source: [Official Canon Web] Links: imageCLASS LBP6030w Support Page | macOS Driver & Utilities Download
2 REPLIES 2
Stephen
Moderator
Moderator
yawatcanon
Thank you!! It works!
