Need Scanner Driver for Canon Imageclass MF743CDW
lindseymcole
Hello!
I am trying to download the scanner driver for my Canon Imageclass MF743CDW printer, but I continue to get the message below.  I have tried multiple different browsers and different laptops and nothing works.  Is there a way to access the scanner driver another way?  Thank you! -LC
Error 404--Not Found
From RFC 2068 Hypertext Transfer Protocol -- HTTP/1.1:
10.4.5 404 Not Found
The server has not found anything matching the Request-URI. No indication is given of whether the condition is temporary or permanent.
If the server does not wish to make this information available to the client, the status code 403 (Forbidden) can be used instead. The 410 (Gone) status code SHOULD be used if the server knows, through some internally configurable mechanism, that an old resource is permanently unavailable and has no forwarding address.
I assume you are downloading for windows?
If so, please use this download. It's 10 months newer than the one you are trying to download.
v1.21.0.2
2 REPLIES 2
v1.21.0.2
Good Afternoon,
I received your note.  Glad I could help.  The 743 is a real Cadillac as far as office printers go.  Enjoy it.  😊
