MX 472 Printer Could Not be Detected on the Network
razzor
This is killing me. I don't know what the problem is. I have tried and tried to install the MX 472, but it will not connect to the network or be found. I had  this printer work before on another router, but after moving, it won't connect. I hae RESET all data, still it won't be found.
I did manage to see it once in my list of networks, but that was only once. When I try to set up using cableless method, the Canon_ij_Setup shows, but the installation won't find it.
I printed the Network Configuration page and this is what I am seeing:
Wireless Lan - Enable
Connection - Inactive
MAC Address - D8:49:2F:B7:9A:56
SSID-BJNPSETUP
Communication Mode - Infrastructure
Channel -
Encryption - none
WEB Key Length - Inactive
IPv4 IP Address -
and the remaining is all blank.
Anyone could help, please....  This is so frustrating.
4 REPLIES 4
Moderator
Moderator
Hi, razzor!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
Thanks and have a great day!
Thanks
But I am struggling why it is not showing on my network. Only the Cannon_ij_Setup shows when doing a cableless setup but it disappears after a time out.
Hi razzor,
Please try using the manual method of connecting your PIXMA MX472 to your Wi-Fi:
https://support.usa.canon.com/kb/index?page=content&id=ART117459
Thanks, but it doesn't work.
When I get to step 8:
When Select access point appears, use the left or right arrows to select the wireless network to connect to:
The printer shows my router but it will not connect. The router offers both 2.4 and 5 G. My computer is usually on 5 G. I haven't experienced this problem before.
Any ideas?
Friends and Family
