07-17-2024 10:08 AM
I've recently changed my internet router and tried to setup network again on the Canon PRINT app. But after selecting my router/wifi name, it did not prompt the password and goes back to the 'Search for available printers" home page.
I have tried to restart my printer etc several times but to no avail.
Appreciate any help! Thank you!
07-20-2024 09:20 AM
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
07-20-2024 10:25 AM
The printer has a 2.4Ghz wireless radio and supports WPA2 / AES encryption. Please ensure you network meets these requirements.
Connection tips:
If applicable, wireless connection set up mode must be enabled
If you are using a dual or tri-band router that uses the same SSID name for all broadcasts, it might be helpful to temporarily disable 5Ghz (and other) broadcasts while a connection is made. You can also give each network a unique name.
If you are using a computer for set up and its running 3rd party AV, these applications have been known to cause detection issues.
Re-running the printer's set up utility is the preferred method of reconfiguring the printer's wireless settings, SSID name and password.
Support - PIXMA MG3670 - Canon Singapore (sg.canon)
