MB2320 - Where do I find the PIN?
GregorZap
Having a hard time getting my old Dell laptop to connect.  It is connecting to FAX and Scan, but not the Printer.  Asking me to enter a PIN from the Printer.
How do I find the PIN?  It suggests on the Printer, but where?
Thank you!
Hello.
Based on your description, you may be trying to add the printer through the Windows add-printer or add-device wizards.  Instead, please download the latest MP Drivers from our website.  This will ensure that the printer is added to the computer correctly.  Visit the following link to download the driver:
MAXIFY MB2320 Drivers & Downloads
3 REPLIES 3
WPS = Wi-Fi Protected SetUp.
The PIN is on your router, not the printer (if supported)
If supported means if your router supports Wi-Fi Protected Setup...  not all do.
See my port here for additional information
If yours does and it has a WPS button, you can use it to pair your printer with the router without having to enter the SSID name and password for your 2.4Ghz wireless network.
If your router doesn't have this feature, you will need to enter the information during software set up.
In that case, this guide will help
Hi Shadowsports,
The thing is, my router and printer are set-up, just not everything seems to be gelling.  From my options to set up the printer, my laptop will caprture the FAX component and the SCanner component, but not the actual printing component.
Does that make sense?  Any ideas?
Hello.
