04-15-2023 09:27 AM
Hi Gang,
I am an experienced Canon customer having a very similar printer before I bought this unit. The issue I have is I'm trying to print from my Pixel 6 Pro phone (Android) like I used to before. I have the Canon plug in app called "Canon Print Service" and when I select a document to print, like from Google Drive, I am not getting the print option like I used to before. Any suggestions would be most welcome and also any app suggestions would be appreciated too
04-15-2023 10:15 AM
Hi Gang,
After playing around with this, I did figure it out. I was looking for simply "Print" off the thee dot menu but what I got was a bunch of editing commands however one of those was "Share & Export"....voila and amongst other commands is the Print command. I am all set on this. Thank you!!
04-15-2023 10:15 AM
Hi Gang,
