02-18-2013 05:37 PM
Hi: Our Pixma MP620 printer/scnanner was working just fine until we had to change routers. Ever since then it doesn't work anymore: the print/scan instruction goes out but then the system gets stuck. I gather the problem is that the Pixma does not recognize the router but I couldn't manage to make it do that by following the manual's instructions. Any suggestions on how to do it? This ought to be really simple! Grateful for your advice, thanks! Henk
02-25-2013 09:07 PM
Hi Henk,
The way to setup your PIXMA MP620 to use a new router is to reinstall the software to your computer. When you changed your router, your network settings changed which caused the wireless connection to go down. Reinstalling the software will reconfigure the PIXMA MP620 wtih your new network settings. So that I can provide specific instructions to reinstall, please reply with your operating system as well as if you have the original disc.
I look forward to assisting you.
04-11-2014 09:50 AM
I have the same issue and dont have the original disc I have an imac OS X version 10.9.2
please could you help ?
03-28-2018 07:06 PM
I am having a similar challenge. I believe that I should uninstall and reinstall the printer-driver software. Canon must come up with an easier and more efficient way to change the settings when the router is changed. I hope someone from Canon is reading these kinds of blogs.
02-27-2019 05:49 PM
