How to connect a PIXMA PRO-100 to a new wireless network?
markw590
I just had to change the wifi network in my home and I have a new modem and router.  The printer worked fine on the old network but I need to connect it to the new network.  The router does not have a WPS button as described in the setup instructions.   How can I get this printer to find my new wifi network?
I have multiple devices in my home that use it to print wirelessly. Will I have to set up each one individually or once the printer's on the new network will they all find it and connect?
1 REPLY 1
If remove the device on any system where it is installed now.  Then uninstall its driver and restart the system.  Now re-run the installation utility.
You will be able to connect the printer to the new wireless network during install on the first device.  Once done, re-running the installer on the other devices should refresh the install so they can also use the printer.
Optional but recommended. I'd assign a static IP to the printer on my router, and install it as an IP printer.  This ensures persistency.
