06-07-2013 07:20 PM
My printer was working but then was turned off. Now I can't get it to print mode. How do I get it out of copy, scan and fax and back to print?
07-27-2015 05:35 PM
07-27-2015 07:31 PM
MerryMary,
Thanks sooo much. I reinstalled the driver and everything is working great. Appreciate all your input!
10-25-2015 08:37 PM
10-25-2015 08:45 PM
04-19-2016 06:11 PM
11-19-2016 11:20 PM
I'm trying to set up on ipadair2 it says no air printer found
12-16-2016 06:43 PM
I believe I have everything set up to receive email message, how ever it shows not connected and keep on showing trying to connect
01-23-2017 09:22 AM
My wireless password contains letters, upper and lower. How do I enter letters and change casing when I'm entering my password during setup?
01-23-2017 11:21 AM
Hi guerryclegg,
At first, your PIXMA MX430 will assume that you are entering in lower case letters. To toggle between lower case letters, upper case letters and numbers, press the Tone (*) key. Each time the key is pressed, the printer will display a different character to the right of Enter passphrase.
If a mistake has been made, press the Left arrow to move the cursor underneath the character to be deleted. Then, press the Back button to delete the character. Enter in the correct character as needed. Press the Right arrow to move the cursor to the end of the passphrase. Continue entering in the passphrase.
04-21-2017 01:55 PM
I tried the link you gave on setting up the wireless: https://www.usa.canon.com/CUSA/assets/app/pdf/wireless/setup_MX432_Win.pdf
and the Page was not Found. Do you have an updated link?
