05-16-2024 10:07 AM
I have tried several times now to install a driver on my Canon G3260. It was printing just fine last week but suddenly it no longer showed up in my printer list and when I tried to add it back, it said no driver found. I downloaded the driver from the Canon site and it went all the way to #3 on the progress bar, even indicating it had detected the printer, but then gave: Installation failed. Click [Back to Top] and restart the setup. I restarted my laptop and tried again with the same result. I an running Windows 11 Home.
05-16-2024 10:37 AM
How are you connecting the printer, and to what device? Directly to a computer, your wireless network?
Downloads for the printer can be found here:
Canon Support for PIXMA G3260 | Canon U.S.A., Inc.
I'd use this driver for windows 11:
Print Driver and Scan Utility Installer Ver.1.02 (Windows)
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDEwMDAxMDkxNDAy&cmp=ABR&lang=EN
If you have any failed instances of the printer installed, I'd remove them, and disconnect the printer's Cable (USB) connection. Now uninstall any drivers, then restart my computer.
Now run the installer I provided, do not connect the printer to USB until you are prompted to do so.
05-16-2024 10:37 AM
05-16-2024 05:25 PM
Thanks shadowsports! That solved the problem.
05-16-2024 06:02 PM
Thank you for your reply and feedback! Glad I could help. 😀
05-17-2024 09:12 AM
Hi again @shadowsports. I now have another problem. I am able to print just fine by my Canon Inkjet Print Utility doesn't work. It says "A driver supported by this software is not installed." Can you point me to the driver for this utility so I can troubleshoot another issue with one color not printing?
