06-01-2023 12:48 PM - edited 06-01-2023 12:57 PM
The Quick Menu Suite which contains scanner settings is not launching from the desktop. I can launch it from the printer but I don't have all of the options available that the desktop Quick Menu provided. I have reloaded the setup drivers but no fix. I believe that the firmware is preventing Quick Menu from launching from the desktop as well as from the Windows Start menu. Please advise. Thank you.
Btw, this is a Windows 10 - 64 bit OS
06-07-2023 12:37 PM
I see you reinstalled the setup drivers but If you have not done so, please click HERE and select software and drivers. Then, scroll down and click load more and try installing the quick menu file by itself. After the file is installed, restart your computer and see if it will come up.
06-07-2023 01:34 PM
I downloaded and installed the updated Quick Menu then rebooted the PC. What happened upon clicking QM: a box appeared saying "checking printer status," and then the box disappeared. I saw the black box appear which was the Quick Menu program but it quickly disappeared. I don't what is hindering the launch of QM. Launching using Administrator privileges doesn't change the outcome.
