03-04-2025
04:01 PM
09:23 AM
Hello, I was having an issue with my printer, Maxify GX6021, this week. I had been using it fine after the OS update to Sequoia, but I don't know if a more recent update to Sequoia 15.3.1 has messed with things. I tried downloading the installation package again starting with "GX6000 series Setup package (Mac)." It cannot find my printer. I have verified that it is indeed connected to the WiFi network (I was able to print from another device). I tried again using the IPv4 address and it was able to find my printer, however it did not automatically select a driver and I cannot manually find a driver. I also tried using the easy connect feature, which also failed. The printer itself says it is successful, but the install utility on my Mac just keeps circling. Is there a compatibility issue with this version of the OS? If there is, is it going to be fixed? I just bought this very expensive printer not that long ago and really do not want to replace a perfectly working machine again as this was a replacement for a printer that was also working perfectly fine, not that old, but would not connect to the scanning utility on my computer after having to replace a perfectly fine router with a very expensive mesh WiFi system due to working remotely taxing the system..... In short, please help as I do not want to spend more money to replace fairly new equipment. Thanks.
