Change passphrase on MX22
Ocam01
I replaced my modem and the network name is the same but we changed passwords.  Now I can not connect to my printer using the new password.  The lan setup does not give me the option to change my passphrase
Problem solved.  The cable company split the signal to 2.4 and 5 ghz and the new setup fixed the problem
2 REPLIES 2
Arthur
Moderator
Moderator
Hello!
So that the Community can help you better, we will need to know more information.
What is the exact model printer you're using (it's usually on the top or front of the unit)?
Do you see any error messages?
Which Computer Operating System are you using (Windows 7/8/10/11 or macOS 10/11/12)?
How do you connect to your printer (USB or WiFi)?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE to find support options in your country.
Thanks and have a great day!
