12-09-2020 08:27 AM
12-09-2020 09:02 AM - edited 12-09-2020 09:05 AM
The printer can only connect to a 2.4Ghz broadcast. If your dLink router is configured for SMART Connect or similar (Using one SSID Name) for both 2.4/5Ghz broadcasts, the printer might have issues connecting and completing set up. Not sure if this applies on your case since we don't know the model of your router. If applicable, temporarily disable this feature and re-enable after set up is complete.
Other possibilities include Firewall or Antivirus software. These can keep the printer from being properly detected, during setup. Last item I can think of is IPv6, sometimes disabling this allows the printer to connect and complete set up.
12-09-2020
09:36 AM
12:05 PM
Thanks for your reply shadowsports.
The model is D-Link DIR-853
I tried disabling the 5Ghz network, but still the same issue.
The router page shows that the printer is connected to the wifi and has an assigned IP Address. I tried to add the printer by referring to the IP address, the printer gets added but not able to detect it for printing.
I have no issue when setting it up on a different network. So i am sure the issue is with the router.
Just adding that on the other network i am able to ping the printer, but when using the D-link i am unable to ping anything, I keep getting the host is unreachable. I believe this may have something to do with the issue.
Any suggestions?
