01-12-2016 07:15 PM
I brought a new MX-922 printer and i am trying to setup the printer. I have gone through the setup multiple times and also did talk to Canon support. Unfortunately i haven't got any response which can solve my problem. I am in IT and i could do all the prelim investigation and steps. I really need some help to solve my printer detection issue.
The network settings for the printer are good. I can see it on the Wireless LAN setup.
Connection : Enabled
SSID : My network name
Signal Strength : 88%
Everything seems to be good at the printer end. I am using WIN 7 and trying to connect the printer from my laptop.
Can Canon support help? I already wanted lot of time on this and thinking of returning this printer.
01-12-2016 07:26 PM
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/CanonEmail or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
04-03-2016 12:53 PM
I'm having the same issue with a MG3550.
Printer shows on the router's DHCP list - OK.
Printer is accessible via the browser & will print head alignment sheets etc. OK.
Printer outputs the network configuration sheet - all fields OK.
None of the computers (all WIN 10) on the network can print (or scan) because "printer is not detected on the network".
Usual attempts at resolution - removed device & all associated software, downloaded latest drivers etc. etc.
Still no headway.
I'm begining to think its a software failure internal to the printer.
(I'm new to the "community" here - so please advise if I've posted in the wrong place.
