10-24-2023 12:59 PM
I was using my MF264DW on my windows 10 PC but when I got a new PC the driver package would not install.
I now have Windows 11 Pro
Version 22H2
OS Build 22621.2428
I tried for ten hours searching online and throughout the forums here for guidance. I tried every fix I found. I think the problem is that the scanner driver has an old certificate or expired certificate. Eventually was able to get almost everything but the scanner to work. I was able to install the following drivers: Canon MF260 UFRII LT, Canon Generic Plus PCL6, Canon Generic Plus PCL6 V250 However no scanner option will work with those drivers.
I downloaded the latest version of the driver from Canon MF260MFDriverV6101WP. I put it into the C drive and ran as administrator. The install package gets stuck at the end of the process and stops me.
When installing over the network I am able to select the printer and it starts, but I get the error: Could not install the scanner driver. Try to install again
When installing over usb, the files go only so far before I get the error: An error occurred while copying files. Try to install again
Currently I can get the scanner to work if I instal a separate instance of the printer using the standard microsoft driver: Microsoft IPP Class Driver, but the windows scan app sucks. There are almost no settings and the scanning is super slow. I want to use the MF Scan Utility, but it says that there is no driver installed.
Is there a setting in the actual menus on the printer itself that might help?
11-04-2023 02:02 PM
I see everyone else is just as stumped as me. Is nobody else having this issue? I have searched and searched. What is the possibility Canon releases an update?
11-04-2023 02:04 PM
Thanks for joining the conversation, edgewriter!
This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or register your Canon gear HERE to access additional support options.
Thanks and have a great day!
11-15-2024 03:01 PM
I know that there has been no response to this. I had the same problem today when installing on a new corporate imaged windows 11 machine. I had to right click on the installer and select install as administrator for it to properly install the scanner part. the print software installed with no issues.
12-06-2024 05:36 PM
Thanks for replying, Greg. I tried installing as admin and it starts but error's out partway through. I have banged my head against the keyboard on this issue all year. Lol. Right now I just have the stock windows driver installed. When I try the updated drivers going through other routes, the system refuses to install them. It says, " You already have the best driver installed"
The windows generic scanner driver sucks.
12-06-2024 05:49 PM
I am unfortunately using the windows supplied one as well. I got the printer to recognize my computer and was able to scan using the printer controls once and then I think my corporate IT blocked it as suspicious behavior as windows pops up with an error every time I try to scan from the printer. Will probably play with it some more in January.
02-19-2025 10:30 AM
I have the same problem
02-19-2025 10:31 AM
I have the same problem😰
