Canon Easy-PhotoPrint Editor says "no printers available"
tbirdman
I have been using Canon's included Easy-PhotoPrint Editor to print basic 4X6 prints on my TS8820 since I purchased it last year. I recently printed some pictures a couple of months ago without any problems. Today when I went to print a picture, I received an error message that said "There are no printers available".
I deleted the program from my computer and re-installed a fresh copy from Canon's website, still getting the same message.
I don't even see a setting that allows me to pick a printer from within the program.
The printer still works, I can scan, print from other programs, just not from Easy-PhotoPrint Editor.
3 REPLIES 3
Moderator
Moderator
Thanks for joining the conversation, tbirdman!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof) and whether your printer talks to your computer via Wi-Fi or a USB cable. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
tbirdman
It is Windows 11, the printer is connected to the PC via cable.
DerrickL
When Canon Easy-PhotoPrint Editor says “no printers available” even though you can print from other Windows apps, the most common cause is that Easy-PhotoPrint Editor isn’t properly seeing (or refreshing) Canon’s communication components for your specific printer on that PC.
Try these in order:
  1. Reinstall/repair Easy-PhotoPrint Editor
  • Uninstall Easy-PhotoPrint Editor from Windows Settings  Apps
  • Reboot
  • Reinstall the latest Easy-PhotoPrint Editor from Canon
(You may already have done this—still worth doing cleanly.)
  1. Reinstall the Canon “IJ” component used by Easy-PhotoPrint Editor Canon community users report that simply downloading and running the installer from ij.start.canon fixed the “no printers available” issue even when the printer was already set up and working in other apps. `
  2. So:
  • Go to ij.start.canon (on the affected Windows 11 PC)
  • Choose your printer model
  • Download the IJ installation program and run it
  • Reboot, then try Easy-PhotoPrint Editor again
  1. Delete and re-add the printer in Windows (not just driver reinstall)
  • Settings  Bluetooth & devices  Printers & scanners
  • Remove the Canon printer device
  • Restart
  • Add it again (USB or Wi‑Fi based on how you connect)
Easy-PhotoPrint Editor can get “stuck” on an old/partial printer registration.
  1. Match USB/Wi‑Fi mode with what Easy-PhotoPrint Editor expects If the printer is temporarily available via USB but Easy-PhotoPrint Editor is looking for a different interface, it can show none.
  • If your printer is connected by USB, ensure it’s actually installed as the same USB-connected device in Windows.
  • If you changed connection type recently or usb port,  try switching back to the original connection mode or port and test.
